According to the Maserati technical bulletin *any* engine (4.2 or 4.7) with an engine number of <148697 is potentially susceptible to variator issues
I agree that extra cranking is not ideal, and not for every start. I was thinking just first start of the day after the car has been sitting a few days. Anyways, getting the cam caps modified sounds like the best solution. My question is if that will truly fix the problem without replacing the variators. Why is there an updated variator if the assumed problem is the absence of a check valve? ThanksThe idea of just sitting there and cranking on a luxury automobile to get oil pressure to prevent a problem down the road seems absurd in my opinion..Everyone around you is gonna think the car won't start and is a POS...If you only have 3300, then pull the cam covers and have the cam caps machined with check valves installed..That will keep the oil in the variator and avoid embarrassment.....Jason
Thanks J, I'll might get a wild hair this winter and pull the cam caps. Where would I send them to? Would they have to go through a certified service center first or could I send them direct to Maserati? Thanks for your helpThe correct fix is the check valves and the updated variators...The problem is a two part one...I wouldn't even worry about it at 3300 miles...I know it seems that it is this huge problem, but your only hearing from people with the issue...Plenty of people are running around with cars with the older variators and no problems....Jason
Thanks, I’m look them up!There is a place in California...They do them for anyone...About 400 bucks....J
looks good if you want to add another potential source for oil leaks.I may just install one of these kits on mine as a preventative measure.
http://engineprelube.com/
Thoughts?
Typically oil leaks originate from rotating shaft seals and old gaskets, not from steel fittings and high quality oil lines, which this kit appears to have.looks good if you want to add another potential source for oil leaks.
i stand by my statement.Typically oil leaks originate from rotating shaft seals and old gaskets, not from steel fittings and high quality oil lines, which this kit appears to have.![]()
If you happen to take a look at a typical factory dry sump system, it's got quiet a few lines and fittings with little issue. Adding an oil accumulator gives a wet sump system some of the benefits of a dry sump in addition to being able to pre-lube the engine. And yes, it's a fleeting argument to say making any type of system more complicated does not invite a higher chance of arising issues, I feel the benefits outweigh any potential and easy to fix leaks.i stand by my statement.
saying "usually" is one step off of assuming.
those two are an attempt to make an engine say, "hold my beer and watch this."
