Under moderate and especially under hard acceleration when the engine is calling for fuel and air, this 28,000 mile O.E.M. equipped, 02 coupe, 6spd. misfires with extreme loss of power while pinging in the exhaust, nasty detonation. CODES: P0300, P0301, P0302, P0303 and P0304 all agree with my ear that miss-firing is going on. Question is what is causing the misfiring which never happens under very light load or acceleration (minimum C.F.M.).
There have been some other codes, P0411 secondary air injection system incorrect flow detected. P1556 Maserati Code which Jeff tells me is also pointing to air injection system. After checking all fuses, I thoroughly checked the engine bay for any open circuit, both electrical and vacuum, all looks good. There is vacuum to the air injection actuation solenoid but the solenoid does not appear to be functioning or receiving a command to open, as I teed into the air injection vacuum circuit with a vacuum gauge and at no time, either during accel or decel, was there any indication of vacuum to the circuit beyond the solenoid.
For kicks and giggles, I bypassed the solenoid with the air injection under full actuation and took the car for a short test drive and there was no difference in the nasty behavior. From the beginning I was suspect as to whether air dumping or not dumping into the exhaust manifolds could cause these type of engine-run characteristics. More so now than before, does it seem more likely that there is another root cause like Mass Air Flow or something that is causing not only the nasty engine-run characteristics, but perhaps due to some kind of safe mode or E.C.M. confusion, the air injection system is not being called upon and itself, is just a symptom like the misfiring.
I am new to Maserati Life, both the blog and the metaphor but I am glad to have found this on-line community of like-minded Maserati dudes.
