My subwoofer needs to be replaced. Do i need to remove both rear seats to get to it? Has anyone here replaced their subwoofers.
I have the same problem. But the back shelf won’t come off. I have all fasteners removed but it is still anchored by the seat belts. Plz help!yes you need remove bottom part and back part then rear shelf.
I have oem one can sell it if you need
You guys know there is also a "sub" under the passenger side footwell, right? (Bass Assembly)You mean our cars have a sub? It sucks so bad it is hard to tell
No i did not know. My car has almost no bass and bass is turned all the way up.You guys know there is also a "sub" under the passenger side footwell, right? (Bass Assembly)
I didnt have to remove the shelf. I got to them by removing both back seats and the the speaker cover in between themI have the same problem. But the back shelf won’t come off. I have all fasteners removed but it is still anchored by the seat belts. Plz help!
Greetings GranTurismo Convertible owners. I cracked the code on replacing a failed original Bose subwoofer the the GranTurismo Convertible. To be clear, this post applies to Convertible owners with two (2) 5 1/2" 4OHM subwoofers located directly between the two rear passengers. After much research, it turns out you cannot order direct (new) replacements for this subwoofer from Maserati or 3rd party parts suppliers. They will sell you the entire rear BASE BOX for the Convertible (plastic housing with 2 subwoofers included), but his is a very expensive part and is probably not necessary.I too need to replace the subwoofers in my cabrio. I have a 2013 and the foam around the subs has torn. I have “repaired “ the subwoofers twice now but the problem has come back again. I will say that it is pretty easy to remove the seats and get access to the sub box. However, I would love to find a good replacement for the speakers. I realize that I can purchase used Bose ones on eBay but I would love to buy a new pair. Has anyone found a good replacement sub that will fit in the existing box without major modifications? Thanks.
I found a solid direct replacement part for the GT Convertible rear Bose subwoofers. See this post from March 29, 2022 below. The part (an Audi 4G0035298) can be found used on Ebay.My subwoofer needs to be replaced. Do i need to remove both rear seats to get to it? Has anyone here replaced their subwoofers.
Outstanding! Thanks for this information.Greetings GranTurismo Convertible owners. I cracked the code on replacing a failed original Bose subwoofer the the GranTurismo Convertible. To be clear, this post applies to Convertible owners with two (2) 5 1/2" 4OHM subwoofers located directly between the two rear passengers. After much research, it turns out you cannot order direct (new) replacements for this subwoofer from Maserati or 3rd party parts suppliers. They will sell you the entire rear BASE BOX for the Convertible (plastic housing with 2 subwoofers included), but his is a very expensive part and is probably not necessary.
OK, here is the fix. It turns out the Convertible rear two Bose subwoofers can be replaced with a Left or Right Front Door Bose Woofer Speaker from a 2012-2018 Audi A6. See Audi Part 4G0035298.
Here are a few pictures. As you can see, it is a perfect fit in every way. The first pictures in the car are both the original Maserati parts. The pictures on the table are side by side comparisons of the Maserati part against the Audi part. The Audi part essentially the same Bose subwoofer. They are both 4OHM speakers. Same exact size. Same depth (which is key). Same mounting hole placement (including the additional holes for the 2 mounting pins). It's an exact copy. View attachment 142288 View attachment 142289 View attachment 142290 View attachment 142291
Here is a link to the Audi USA parts site: Link to Audi 2012-2018 Bose Subwoofer 4G0035298
This Audi Bose subwoofer can be found on Ebay for about $100.00.
Note, I found the steps to access the GT Convertible's rear subwoofers to be fairly easy. Remove the two rear seat bottoms. Then, remove the lower bolts to the two rear seat back rests. I did not find it necessary to fully remove the two rear backrests. Instead, I just tilted them forward, which gave me ample access to the screws that hold the center trim cover over the subwoofers (i.e., with the plastic trim piece that houses the subwoofer grills) in place. Remove that plastic trim piece in its entirely, and you then have open access to the two rear Bose subwoofers. Good luck.
View attachment 142293 View attachment 142294 View attachment 142295
That's pure gold - thanks for that.Greetings GranTurismo Convertible owners. I cracked the code on replacing a failed original Bose subwoofer the the GranTurismo Convertible. To be clear, this post applies to Convertible owners with two (2) 5 1/2" 4OHM subwoofers located directly between the two rear passengers. After much research, it turns out you cannot order direct (new) replacements for this subwoofer from Maserati or 3rd party parts suppliers. They will sell you the entire rear BASE BOX for the Convertible (plastic housing with 2 subwoofers included), but his is a very expensive part and is probably not necessary.
It really is 3 cars in one!Now I wish I had a Cabriolet! 😝 Great info!
Wow, @Mpwise144 Mahalo nui loa. 2x Maitais to you sir!
now, the only issue is that the actual speakers are kinda hard to find (on ebay) and are still very expensive OE. I bought a used GT sub box from ebay 2 years ago...of course, the speakers were barely better than my blown ones. I wish we could easily drop in an actual replacement speaker from a QUALITY brand lol (not blows).
And as though that’s not bad enough, mine gets really lousy radio reception - especially AM stations. I wonder if the Aucar head would solve that?All Italian cars have crappy sound systems. My 430 Spider originally came with an ancient Becker's radio and only 2 speakers! (With the loud engine behind you, though, you can't even hear it. Lol).
Now days, most current Maserati's come with Harmon Kardon (which still sucks).
Contrast this with the Germans. BMW offers Bowers & Wilkins, Mercedes with Burmester, and Audi with Bang & Olufsen. All top-end.
Italians are just not good with offering bells & whistles on their cars. Their focus is on the driving experience.
I guess tha's what's wrong with mine, I have 2012 GT convertible. It sounds like the back speakers are blownWould be interested to know what speakers you are referring. I have same issue in my convertible.
