Hi All!
Looking for a little help on this issue: (For those of you interested in a story, please read my novel; I had no idea I could be so descriptive in my explanation. For those who like bullet points, I summarized at the bottom, lol)
Was out on a drive a little while back, had done some easy country road miles, so everything was warmed up and running smoothly. Gave it a good acceleration on the initial turn onto a highway and then cruised a couple miles at about 70mph. Coming into town, slowed for a red light and heard what I at first thought might have been some leaky exhaust noise. Checked my gauges and both Temp and Pressure read at normal. While stopped, I rolled down the windows and could hear a very raspy noise. Puled over immediately into a parking lot and before I shut her down I popped the bonnet and took a quick look/listen.
Sounded very mechanical; quick tapping; top end noise, maybe like a desmo? At this point the coolant started running past my feet as it flowed down the hill. Further examination showed it to be making a drip path following the car into the lot. Shut everything down and thought out what had happened. After a bit I checked for engine codes, of which there were none. Also checked engine oil level, and was very shocked to see nothing reading on the stick. There was no oil under the car, none following the car into the lot, and had seen no leaks at home either. Had done a complete fluids service myself back in February, and had done only a few thousand miles since. I have changed my own fluids many times before, and never had any trouble going 8k miles without needing to top off. Still, no excuse for not being more methodical in checking levels, but I do not believe it would be THAT low for any reason.
I was able to run across the street and grab some water and oil. I refilled the coolant reservoir and checked for any leaks in the lines; did not see any. Took about a quart of oil for me to read just the tip of the dipstick, but did not see any leaks with the oil either. Topped off the oil and started the engine just long enough to see if the noise would die down/go away or if any more leaks would show. No leaks, but same damn noise. Ended up getting towed back home where I have spent some free time looking into this. Much like with flying, I know just enough about engines to make me dangerous, but not useful...
Both coolant and oil systems have been completely topped off, and against my gut feeling I did start the car again to let things cycle. No leaks have shown themselves, either while running, or with the car sitting for weeks. Noise was still present. Things have sat still for a bit, and I drained some oil from the plug on the bottom of the engine the other day. Picture is attached, but I saw no metallic bits/dust; however, I did find pieces of white, rubbery material. Gasket material, says I, but from where?
Summary:
-Engine began to make raspy noise; quick, mechanical, ticking sound.
-Coolant Temp and Oil Pressure read normal.
-No Engine Codes.
-Coolant leaked out pulling into lot and dumped out after parking.
-No oil leaks present anywhere, but dipstick showed no reading (only a few thousand miles since last oil change).
-No leaks showing at all in past weeks.
-Noise was still present at last start-up (only ran twice, briefly, since 1st incident).
-Oil showed no sign of metallic deposits, but did show what looks like gasket.
I've read all sorts of posts that deal with anything from lifter noise, to VVT, to oil/coolant pump, to "some...THING on the wing," but I can't seem to wrap my head around it. Does anyone have any ideas, or a direction I should start looking in? Thanks for your help!
Summary:
-No Engine Codes.
