Radiator Fan Stuck On?
9.8K views 17 replies 9 participants last post by  Sobol04
#1 ·
It's been cold here (32 this morning on the way to work) and I noticed the fan seems to run all the time. Anyone else experience this?
#6 ·
No codes just the drone of the fans running all the time but the car is running way too cool (1/4 way). May eventually throw a code. If anyone knows where the sensor is, please let me know.
#8 · (Edited)
Bee, i just got home where keep records in my pc of everything that us guys are repairing in a folder and i found the one about fans staying on. it paid off in this case. MaseratiNashville put up a thread (OBDII PORT LOCATION). When u get to it scroll down to see what RAMP says cuz he pinpoints the problem. At the bottom of the radiator there is a resistor and the ceramic covering that is decaying. sorry but i had a hard time trying to copy and paste it. Lorenz
#10 ·
Any error with the cooling temperature sensing circuit will result in the Motronic unit defaulting the fans to high speed. It is generally caused by a thermastat running cold. 170 deg rather then the 190 is enough for it to flag an error. Early cars had software problems associated with the comparative sensor after the thermastat, this was a software issue and most cars have been repaired and the sensor after the thermastat should be unplugged and tucked out the way. This was 2002 and possible some very early 2003 cars.
Generally this will cause a check engine light but it does need to occure on two consecutive drives cycles to illuminate the mil.
Best of luck.
#14 ·
This is spot on! My fans were running at high all the time. Pulled codes and found a "Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)". When I cleared the codes the fans stopped. Let the car idle for a few minutes and they came on low and cycled based on coolant temp.
Thanks! This saved me a trip to the shop.
#11 ·
Ummmmm. Started the car last night and for the first time in 3 days.... No fans. Temp is perfect (just below half way). Now I'm wondering if I have fans at all. THIS CAR IS DRIVING ME CRAZY :)
