I’ve had my ‘05 cambiocorsa coupe for about a year now and it had around 52k miles. The previous owner had the car for about 8 years and stated he never had the clutch changed. After I owned the car for a bit, I noticed there would be an intermittent “slip” of the clutch, especially when attempting to accelerate from a dead stop and noticing that the clutch would not bite as it should. Clutch wear was at 25% worn. (I have a Launch diag tool)
I started to take apart the car on my gojack lift (a great thing to have, and it works well for this job!). I removed the trans and slid it back, resting it on a jack. Then I removed the torque tube and bell housing. The clutch actually looked like it was in good shape, but I noticed the throw out bearing would intermittently get stuck on the shaft while manually moving it in and out. There was quite a bit of built up dirt here that seemed to be holding the throw out bearing in place, instead of allowing it to return.
So I ended up replacing the clutch assembly, pilot bearing, F1 sensor, bellhousing bearing, Hill Engineering throwout bearing, preload springs, rear main seal. The low pressure f1 hoses on the trans were very hard and cracking, I replaced them with a hose kit from ASM. I also replaced the F1 pump motor with a brand new alfa selespeed part. Then I had some of the chassis parts/exhaust bracket sandblasted and powdercoated.
Since I replaced the hoses, I bled the F1 system with Pentosin CHF11S and bled it at the actuator, before re-installing it on the trans. I also ended up installing a BMC air filter and ASM secondary de-cat pipes.
So far so good, the clutch definitely bites much better than before! I love this car! Now in the process of bedding-in the clutch and adjusting the PIS. Enjoy the photos!
