My local mechanic said I might have a faulty cam variator. Anyone has this problem? please advise?
I'm in agreement with Jason's post, It's far too difficult to give you an answer that has a leg to stand on.Josh, in regards to Maserati engines, do you think some engines will never have its variators go bad or all of them will go bad eventually?
What do you think?
Hi, can you give me the /contact details/address of the machine shop that will do this repair on the caps? I have a 4200 QP has faulty caps. the non return valve on the cap broke on the left side. will they replace the valve? Im all the way in Kenya so would appriciate the help.Amending my post above.
The variator and solenoid will be a new part, the cam bearing cap will be sent to MNA to be machined and sent back to be put back on the motor.
Usually it is a misfire code, then we have to check the electronic timing values to make sure they are within spec.
There is no clear indication as to why this occurs. I have seen cars come in that barely exhibit the "chatter" , and I have seen them where there is a clear audible misfire in conjunction with the chatter. I have also seen cars that the client states there is a chatter, but when it gets here.....nothing. We keep the car for a couple days to perform cold starts and have a video recorder on it every time we start it. It may be three or four days before we can get the car to do it.
If your car does this intermittently, I recommend recording your cold starts to catch it in the act. This will save a great deal of down time with your dealer.
Hi Jason,FYI, I am about to proactively have my cam caps machined by the machine shop in Napa Valley that machines and adds the oil check valves (TEM Performance).
My car has 20K miles and I want to be sure to NOT have the variator problem. So, I ordered a kit from Maserati (for about $140) that contains the check valves, the valve cover gaskets and plug seals, and will pull the valve covers, pull the two front (bridged) cam caps, sent it out for machining and install of the check valves ($300) and then reinstall.
Hope to never have this $5K to $7K problem then.
I am on 2nd variator full replacement. First time it was under warranty and this time I have to pay. They do know it's an issue but not sure thet care at MNA. I contacted them to see if they could help defray cost and answer was no.Anyone gotten any support from MNA on an out-of-warranty car? We've got an '08 that went from a slight rattle to a full-blown issue with misfires in about a week. They obviously know it's an issue with the engine but I haven't gotten anywhere yet.
Anyone have a full copy of Tech Bulletin MTB-200917 that addresses it? I only have the first page.
I appreciate any advice on pursuing this.
These cars have a slightly "rough" idle naturally. It's best to have someone that spends a lot of time with these cars give you an opinion. If the engine is really running rough, you will most likely have driveability issues and a CEL with faults of some sort.
Brian, without being rude...there is a lot you're not seeing with the parts diagram if you believe 16hrs is excessive and the engine doesn't need to be re-timed.
I will usually charge (EDIT: 20hrs for front cover reseal, about 30hrs for variators.) in anticipation of complications...like spending extra time fighting with the crank pulley. The dealers may be doing the job for 16hrs due to factory warranty pay restrictions.
The mechanical variator in the QP engine is different from that in the other 4.2L engines. It is however shared with the Ferrari engine...which has little to no trouble with failure. So figure that one out...
These engines are designed with a base mechanical camshaft timing, which is modified electronically as the RPM's increase to broaden the power band. It is imperative to set this base timing correctly.
The variator interfaces between the timing chain and camshaft. There is nearly no way to change the variator and not be concerned that the timing is affected.
I'm really shocked that an oil additive improved the feel of the engine. I hope it was coincidental. Generally, a fuel additive could have that effect. The oil additive may contribute to a quieter engine, however. I tried a half bottle of Ferrari Tutela to improve my variator sound, but had no luck.Just a quick note that I took my QP in for work on the variators and they tried running a can of BG MOA through it first. It's only been about a week but it's cleared up about 99% of the rough running and occasional noise.
