I just saw this .. holy crap, 40 views and no one knows the answer ? 🥺 But it could be for the same reason I’m stumped which is “ Siri radio “ ? ( I have no clue what that is ..linked to an Apple device..? )
However, if you’re simply referring to the GT’s standard NIT / radio, and assuming the 2015 has the same radio as in the 2013 cars ( which is what I have ) if I recall correctly, I think this is how to reset your preset stations :
Use the buttons on the left side of the radio to select the band you want ; FM 1, FM2, AM, etc.. Then use the buttons on the right hand side to find the frequency / station you want : the arrows will automatically scroll and stop at the stations with sufficient signal , or you can turn the round button which will manually get you to the station frequency number you want to set in memory . When you get to each radio station you want , press and hold the numbers buttons in the center panel for about 3-5 seconds and it’ll set that station in memory, overriding anything which was preset there before I think you can only do that with buttons 1 - 6 so just 6 different stations presets possible , but that’s for each band you chose .
It’s been at least four years since I’ve done this so not 100% certain of what I posted, but I think that’s how it’s done .
Hopefully by tomorrow someone who knows how to operate the NIT system better than me, will chime in here with the right instructions, if mine are not correct ..
