In advance, thanks for the help to all. New owner of a 66 mistral. Likely the car had not been driven regularly. Still has the Lucas fuel injection unit. First day out of the garage, and as things warmed up, the fuel pump seemed to fluctuate. Found a problem with the leads on the starter switch, and cleaned. But fuel pump finally seemed to die. It did restart after cooling, but died again. Ignition switch hot to the touch. Finally pump would not activate when ignition was on.
Will try again in the am. Filter problem?? Pump likely died??
What sort of fuel pressure is expected?
Also might I ask typical idle RPM?
Best. Mark, Atlanta
Best. Mark, Atlanta
