My local mechanic said I might have a faulty cam variator. Anyone has this problem? please advise?
Never seen that other number. What's the source? Just curiousThe M139A engines manufactured after September 2010, starting with Engine Number 148697 or 157854 (different sources say different things), has the factory variator upgrade. Engine number is located on a tag at the 9 o'clock position on the bell housing when looking forward.
That is interesting. CheersIn the QP factory replacement parts catalog, the variator changes to a new part number starting at Engine Number 157855. That's not the only change required for a complete fix (check valves on the end caps), but I'm told that's when the variator changed at the factory.
I was wondering if that might be it. Do you know your engine number?Just got the call from the dealer. Needs cam variator solenoids. ??
