Hi Team - Just got my first Maserati - 4200 Coupe GT with a manual. Had to replace all AC components (...) and everything worked for two weeks until blower stopped. I checked the fuses and this link was quite helpful.
Three questions - before I start digging into the resistors etc. I want to make sure I'm checking all the connectors. The five wire connector atop the blower seems secure. In this thread I saw a different connector melted. Does anyone know what/where this is?
Are there any relays I should be checking? I know we tested when replacing the AC compressor but don't see any blower relays which seems strange.
Second, if I do replace the motor, is there a comparable part as I can't seem to find a new one. Do any Fiat parts work (like the TV valve?
Appreciate all your help! Thank you
www.maseratilife.com
How to remove AC/Heater Fan??
Well my AC/Heater Fan has been working intermittently. Before I just replace a 400+ fan motor, I would like to see if I could take it apart and see if it is just bad brushes or something that could be fixed. Also need to see if it is easy enough to remove without taking the whole car apart...
