My 2003 Spyder reads P1420 "Manufacturer control". Can anyone tell me what this specifically means? I assume it is Maserati's use of the number. Bob Zim
I would start with a sensor fault ahead of blaming the cats - unless the car has some sort of impact damage to the exhaust. The only information I can source is that it applies to bank 1 on a Mazda - perhaps another forum member has access to the Maser specific codes to verify this is the same? Alternatively, a call to a local Maser dealership may be helpful to identify.I think that indicates that the cat isn't reaching operating temp by the time the o2 sensor comes out of the closed loop in start up mode. It probably means that you primary cat is on its way out, it also might have already have fallen apart thats why it cant reach temp.
Looks like I was barking up the wrong tree - the expertise is much apprecaited.When the first # in the OBD2 code is a 1...In like P1420...You can't just google generic codes as it is manufacture specific...I'm showing a P1420 as an issue with the purge valve....Jason
Purge valve = washer valve. They are the same thing. Ignore the Cat related messages in this thread. I was 100% incorrect in my initial posts. Valve is located where I pictured earlier.Thanks Jason - I will do both. Bob Zim
Jason and Sanmian - I purchased the new purge valve and motor - attempted to install but have not been able to so far. The power plug does nor want to release. Trying to pull the part up from it's canister there is a hose attached to the bottom preventing it from coming up and no access to it's clamp, aaaaand how do you release the hose clamps to begin with ?? Any suggestions ?P1420 is for the canister purge valve....Jason
