Hi
I change the brake fluid on my 4200 CC using a power bleeder applying 10psi pressure.
Now the ABS warning light stay on on my 4200 CC.
No error code on the ECU with x431 reader. Brake fluid level sensor seems ok: there’s continuity when the tank is full and no continuity when it’s empty. I guess it’s the right behavior for that sensor.
When I drive the car, intermittently the MSP and skyhook warning lights turn on as well few seconds and then I can read the code C1401 “Speed Signal” on the skyhook ecu.
Any idea?
thank you!
Xavier
Any idea?
thank you!
Xavier
