Maserati will not start everything on the dash is flashing key is stuck in the ignition
That "electrical guy" definitely twisted those sensor wires together. 🤣💯So the shop figured out the brake sensor issue without any feedback for me by the time I called them back their “ electrical guy” took care of it. He is now running through modules and believes there could be a BCM that needs to be replaced so it sounds like there may be a trip for me to the Maserati dealership. they did state with other dealerships that they’ve had luck with getting them to give them codes for BCM’s. I don’t know in holding pattern now until I hear more tomorrow.
That’s exactly what they told me he did! 😂That "electrical guy" definitely twisted those sensor wires together. 🤣💯
Did you hit the brakes, I forgot about that after I found a mouse had made a home just under the hood near windshield after I vacuumed it out I tried to start it and lit up like a Christmas tree also wouldn’t shift out of reverse and I had her in neutral when I shut her down , hit the brakes went to neutral and started right up.Well, bad news swapped out the battery and everything was the same dash still shows multiple errors.
I don't think this gonna be a good experience for you...In the South, we call it getting taking out behind the woodshed...JasonWell, looks like I’ll be at the Maserati dealership Friday morning 7:30….🥳
Prayers sent, bro. 🙏🏾I was at the Maserati dealer today for four hours from 8 to 12 that charge was $400 for diagnosis, the concerning part is they were still still scratching their heads a little bit they believe it is a body computer control unit but they said if that’s not it, they will not charge me, but they are ordering one in, should be in a week and I’ll be back at the dealership. I was told the body computer control unit is $600, so as it stands at $1000.
Thank you brother 🙏🏼Prayers sent, bro. 🙏🏾
