Maserati will not start everything on the dash is flashing key is stuck in the ignition
From what i have seen from others this may be a battery issue. Try giving it a charge if you have a charger (recommended over doing a jump start)Maserati will not start everything on the dash is flashing key is stuck in the ignition
Would it be better just to replace the battery? I don’t have a charger by the time I buy a charger I might as well get a battery.From what i have seen from others this may be a battery issue. Try giving it a charge if you have a charger (recommended over doing a jump start)
Good Luck!
Roger that thank you sir, I have read a lot about these batteries causing issues boy they weren’t lying.Owners manual details where the button is near the key to get the key out of ignition with a dead battery.
Make sure you buy the big battery, H8 I believe as some catalogs show the smaller H6.
I agree, but I did that last night and drove it and now this. Can you educate me on any connections that may have been around I use the jackpoints didn’t stress anything underneath. Really just looking for a starting point I don’t know if just doing the battery because it is the best thing to do or not.I really don't see how you could get all that from changing pads and rotors, but I would go back and look over your work...J
Yes, most catalogs, and almost all online reference guides incorrectly list the battery as a H6, it should be H8 !Owners manual details where the button is near the key to get the key out of ignition with a dead battery.
Thanks for the feedback. I did get the key out and this is the battery. I’m going to go get.Yes, most catalogs, and almost all online reference guides incorrectly list the battery as a H6, it should be H8 !
Removing the key is easy ; there is a small plastic cap on the steering column , very close to the ignition slot , just pry it out ( can even do it with a fingernail ) and then use anything like a paper clip tip, or a blunt pin, or a similar item to push in the button that’s inside , and that will release the key .
