Hello everyone, I hope everyone is doing well.
I was doing a brake/clutch fluid change on my 04 coupe gt. Brakes all went well with no issue.
Then when I went to bleed the clutch and nothing. I can't get the fluid to come through. I know that the clutch pedal needs to be pulled all the way back for it to fill and then pumped. I can hear it gurgling about and do see a little fluid come through but I cannot get it to fully bleed through. Even when using a hand vacuum pump.
Clearly I am doing something wrong. but can't quite figure it out.
Any insight would be of great help.
Thank you in advance for any help.
