1 - 20 of 37 Posts
aquaranti
can bus problems convertible top wont work from inside the car but if i go outside the car i can operate it from door key switch. also passenger window goes down in increments when odometer was flashing the window went down withouta problem , also top worked inside car , now i did a restet and the odometer stays on without blimking and top wont work . i get a whole bunch of codes and low voltage codes . any help appreciated
You need to figure out why you are getting low voltages codes for starters...Do you have a good battery and charging system? Jason
Do you have a system not programmed warning? It sounds like it is just a top not working at this point? How did you come up with it was a CAN bus problem? J
Discussion starter · #6 ·
roof problem see manual top only works from door lock , passenger windoe goes down in increments body computer b- can error line faulty bus off. internal roof b1001 ,2,6,6,7 luggage compartmrnt u1602 bus off no signal . i am using the autel reader
Discussion starter · #9 ·
erased codes these would not erase
NBC Body computer line error b-can U1602
Nit Infotelematic node U1704 node not present
NVB Luggage Compartment node U1602 can line error (Bus Off no signal u1601 unknown trouble code
Discussion starter · #10 ·
Clear all the faults all the faults from all modules and see what comes back...J
I cleared all faults however 3 would not clear
1, nbc body computer fault 1 b can line error U1602
2, NIT infotelematic node U1704 node not present ( My lights are steering wheel buttons not illuminating )
3,NVB Luggage Compartment node Can Line error (Bus-Off no signal U1602 and U1601 Unknown trouble code
Hope this helps ,Thank you for taking your time in helping me
Discussion starter · #12 ·
I would check all your fuses for starters...Don't forget about the fusebox next to the battery..J
ok will do
i checked them all now the audometer blinks and the roof works from inside and occasionaly while driving i get roof inoperable message . ran a scan and still get 2 faults for luggage compartment node and body computer fault but at least the roof works from inside and the passenger window goes down freely while operating from drivers side controls . ( the window will go down in increments when the roof operational message pops up )perhaps its a software glitch in the body computer. your thoughts
Discussion starter · #14 ·
i don,t know how to communicate with them , i may have to reluctantly go to the dealer, but i thought I can get some info here how to proceed . The italian cars are just as bad as the jags when it comes to electronics.
Discussion starter · #15 ·
i did have the drive by wire installed about 3 years ago i dont know if this hurt anything
You use the scanner...As far as the electronics ...All modern cars have a ton of modules on them and sophisticated networks so that is what kinda breaks on a modern car..You don't get all these fancy features without a downfall...Maserati electronics are fine IMO and no worse than other European car of the same age range...It is mostly all the same stuff...J
  • Like
Reactions: Juris
Discussion starter · #17 ·
for now ill live with it convertible tops always have their quirks . as for the roof operation light coming on once in a while i can deal with it , and ill put a black piece of tape over the mileage audometer . out of sight out of mind.
Ok, electrical tape over a warning light is about as 1/2 ass as you can get ...You are better than that...You are loosing street cred with me here...It is not going to fix itself and you can't sell a car with tape on the dashboard ...J
Discussion starter · #19 ·
your right For now this is the fix , maserati dealer is about 150 miles away from me , I will have to see when I can bring the car there . Im just afraid that they will fix one thing and screw up something else . I have heard horror stories about dealerships . furthermore I had a drive by wire installed and if they do screw something up they can blame it on that.
1 - 20 of 37 Posts
