Bought a '07 QP with about 71k miles on it hoping to restore her to her original beauty. After much scrubbing with rubbing alcohol and getting the sticky button issue taken care of it was time to tackle the transmission. When shifting from 1st to 2nd to 3rd on a cold engine, very hard shift and lurching. Went away after warming up. Changed the oil and the magnets had this sticky, almost grease like stuff on them. Less than 3.5L drained out (VERY black oil) but a little over 6L back into it so I'm sure it was low and overheating.
Any worries that severe damage was done to it? The car shifts fine now, like butter...smooth as silk. Amazing difference! Also added a bottle of Lucas xmission fix as recommended by some on here. I had bought the replacement electrical connector sleeve, thinking to also change this out but.....really? I don't see any way to change this out without removing the exhaust pipe here and didn't plan on getting that involved so did not do it this go-round. It does show a little bit of leakage. Maybe the Lucas will seal it up....time will tell.
Last quick question.....Evidently this ZF tranny holds 9L of oil but I only refilled 6L so guessing the rest is in the cooler, lines and torque converter. Should I replace the oil again after about 5k miles to try and get the rest of the burnt oil out? Thoughts?
