This has come up in other threads a few times + in e-mails, so I'm starting its own thread.
First of all, stock QP wheel sizes: (lugs: 5x114mm)
Front (offset) [tire size], Rear (offset) [tire size]
18x8.5 (54mm) [245/45], 18x10.5 (46mm) [285/40]
19x8.5 (54mm) [245/40], 19x10.5 (46mm) [285/35]
20x8.5 (54mm) [245/35], 20x10.5 (46mm) [285/30]*
* I need to double check offset of the stock 20" wheels (unless someone else here can confirm that?)
Almost all of these are available on Tirerack - prices quoted from Tirerack.com unless otherwise noted.
Snow Tires:
245/45-18
+ Bridgestone Blizzak LM-25 ($194-230)
Continental ContiWinterContact TS810S ($212)
+ Dunlop Winter Sport M3 ($217)
Dunlop Winter Sport M3 DSST ($237)
Michelin Pilot Alpin PA2 ($205)
+ Pirelli Winter 240 Sottozero ($199)
285/40-18
+ Pirelli Winter 240 Sottozero ($341)
245/40-19
+ Pirelli Winter 240 Sottozero 98V (Not currently on Tirerack - listed on Pirelli's Site)
+ Dunlop SP Winter Sport M3 ($373 MSRP - Tirerack.com doesn't currently list these, however Dunlop's website does, with a dealer locator)
285/35-19
+ Pirelli Winter 240 Sottozero 103V (Not currently on Tirerack - listed on Pirelli's Site - We can order these from Maserati)
245/35-19 (None available that I am aware of)
255/35-19 (A slight upsize that works fine)
+ Pirelli Winter 240 Sottozero 97V (Not on Tirerack - Pirelli site)
+ Nokian WRG2 97W (Not on Tirerack - this is one we have ordered through our local Tires Plus)
285/30-20
+ Pirelli Winter 240 Sottozero 99V ($394) - Dealers can order these directly from Maserati as well, but by the time you get them they've been marked up at least 2-3x
+ Recommended
Best Options
My personal preference - 4x 18x8.5 wheels and tires
This is the overall cheapest & easiest setup - you can rotate the tires year to year, you don't have to worry about the wheels getting eaten up, and its cheaper & safer than having tires mounted and dismounted every fall\spring.
The rear wheels will be inset a bit and look kind of funny, but we are working on finding a spacer that will move them out, or you could also order a different offset and have specific front and rear wheels. Makes rotation harder, but technically the better option vs. spacers.
For owners with Quattroportes with 19" wheels we have also just ordered two additional front wheels, and run the 245/45-19 Dunlops on all four. Good option if you want to keep the stock wheel size.
The 8.5" rear wheel width works better in the snow as it cuts down the skiing tendencies quite a bit. And as an added bonus the tires are usually cheaper.
I have only driven QP's on the 19x8.5 and 18x8.5 setups. Our demo is currently running on 18x8.5, as well as my GM's car. I've driven them in up to 4" of snow with good results. Snow tires in general don't have the performance our summer tires so, so you really aren't hurt much by the width decrease - performance seems to be pretty good and everything reacts predictably.
Wheels
We've been ordering Rial 18x8.5 wheels with 54mm offset x4 for the QP and GT's. You could order the different offset for the rear to get the correct outer width, but we prefer function over form on these, and the matching offset makes rotation much easier. We haven't been able to get the Rial's lately (unsure if its due to that size no longer being offered, or we bought up the stock, or what) so we have been buying Sport Editions. Both of these are\were available directly from Tirerack, although you may have to call to get what you really want.
Links:
Tires:
http://www.us.pirelli.com/web/catal...ER.xml&prodotto=14668&vehicleType=CAR-SUV-VAN
http://www.dunloptires.com/dunlop/size.jsp
Wheels
http://www.tirerack.com/wheels/Whee...odel=Porto&wheelFinish=Bright+Satin+Sil+Paint
http://www.tirerack.com/wheels/Whee...el=CD&wheelFinish=Bright+Satin+w/Machined+Lip
Snow Tires:
245/45-18
285/40-18
245/40-19
285/35-19
285/30-20
+ Recommended
Best Options
Wheels
Links:
Tires:
Wheels
