Passing this along in case anyone needs to repair their window regulator pin. Left and right window pins in kit.
Looks like good quality - Made in USA. Looks like these guys may be able to help in reproducing NLA parts that our cars may need.
Maserati M138 Coupe Spyder GranSport Window Regulator Repair Pin Pair (2) | eBay
Whether your window regulator is currently broken or you would like to upgrade your regulator to avoid a window stuck in the down position, you'll be relieved to replace the delicate pot metal window regulator pin in your Maserati Coupe, Spyder, or GranSport with our 303 Stainless Steel USA-made CNC'd window repair pin.
Replacement regulators will fail over time; the solution is to replace the pin in your existing regulator.
A simple design, our BlythBros. Design pin is constructed from high-quality 303 Stainless Steel, and will not fail like the original pot metal. The fit is precise, owing to its CNC manufacturing process.
Assembly is as simple as clipping the part in using the high-quality, USA-made bowed e-clip provided with each window regulator pin.
Sold as a set (left and right side). A set takes care of an entire car - only need to order a quantity of (1) to receive a pin and e-clip for each side. If one of your window regulators has failed, it's only a matter of time before the other side fails, so we recommend replacing both at once to avoid future disappointment.
Thank you from the BlythBrosDesign.com team!
About Us
About Us
