Usually the GS starts up with a lovely growl, but very occasionally it sort of sputters to life. It's quite embarrassing actually. Seems to happen after it's been driven, parked, and then driven again very shortly after.
Check to make sure all of the vacuum lines are tight around the engine. I had one loose, and it seemed to do something similar. Looked like the tie moved down the hose, loose enough you could pull it right off. Has been better on mine since i re-tied it.
