On many vehicles the offsets are stamped on the inside of the wheel. I do not know if this is the case with maserati.
It's a pain to remove a wheel but if you don't get a response from one of the wizards here soon maybe removing the wheel will help by giving the info you need.
As far as determining additional offset, lightly tape a piece of cardboard down the body over the wheel well area and then measure the space from the wheel body line as depicted by the cardboard to the tire. That will tell you how much more you will need.
2006 Gransport LE
Does anyone know the proper wheel offsets for the Front and Rears for coupes?
Or what is the recommended offset in order to get wheels to sit flush with the car?
Thanks!
Front - 63.7
Rear - 55.5
Everything you ever wanted to know...
http://www.tirerack.com/wheels/resu...=Coupe&autoYear=2002&autoModClar=Without+TPMS
Front Fitment
19x8.5
19x8.5
Original Price:
Now 0% Off: $0 (each)
$1,160 $1,160 (each) Price:
$0 (each)
See price in cart Offset: 55mm
Backspacing: 6.97"
Bolt Pattern: 5-108
Rec. Tire Size:235/35-19
Weight: 25.1lbs.
Est. Availability: Fewer than 2
Rear Fitment
19x10
19x10
Original Price:$0 (each)Now 0% Off:$1,240 $1,240 (each)
Price:
$0 (each)
See price in cart
Offset: 52mm
Backspacing: 7.60"
Bolt Pattern: 5-108
Rec. Tire Size:275/30-19
Weight: 25.6lbs.
Est. Availability: Fewer than 3
Remove Opt. Rear Fitment
View Optional Rear Fitment
View on Vehicle Closeup / Detail
