1 - 12 of 12 Posts
All you that get your skyhook suspension lowered, do you know the right settings for wheel allignment?
I called some shops and asked if they could do a wheel allignment after I got it lowered, but no one seems to know the right settings for a Maserati (this is Denmark)
Anyone with some input?
i have the same problem,
anyone have the aligning settings...
thanks,
Willie
surfnirnava said:
I posted the measurements on this site a while back but I didnt keep a seperate note of them. Try a search of the forum - they are there somewhere!
Please help me find this, I tried searching the site and I found lots of quotes from you, but not about wheel allignment settings.
Regards
Niw
here it is. It was under the 'Unleashing 390 horses....' thread. I have copied and pasted my note, hope it helps.
Tim
Had my wheels aligned and it made a big difference on the road. Previously my front tyres wore out on the insides leaving lots of tread accross two thirds of the tyre - the car ate front tyres every 5k miles! I now get much better, even, wear.
You do need a good alignment centre though and they need to have the shims to be able to make any changes. Having my four wheels done cost £211.
It is also worth making sure the centre has the correct measurements. These are for a 4200 Coupe:
Fronts
Toe-in 2.5+/- 0.5mm
Caster +4 degrees 35' +/- 6'
Camber -20' +/- 10'
Rears
Toe-in 4.5 +/- 0.5mm
Camber -1degree 10' +/- 10'
1 - 12 of 12 Posts
