1 - 20 of 29 Posts
So, I'm waist deep in the dreaded matrix replacement process when I come across this little switch jammed between the console and the glove box. It's in the on position, and clearly an aftermarket switch. The picture shows as far back as I can trace it's pigtail before it disappears further into the heart of the vehicle. I know it could be an aftermarket kill switch or even the switch for a performance chipset, but I'm a little nervous to just go throwing some strange switch just to see what it does...I mean, it could be for an ejection seat or a self destruct mechanism too, right? Lol.
Any thoughts on things I could look into to learn what it is without actually flipping the switch would be appreciated.
You are most likely just gonna have to follow the wires...Any replies on here you get are gonna be an educated guess as far as something like that goes....Jason
My guess is its a kill switch. If it were mine I would just flip it when everything is off and see if it she will start. But the safe thing to do is to trace the wires.
Are yellow wires and connectors not usually reserved for SRS/airbag wiring? My guess would be it's to disable the passenger side bag if car not fitted with the key switch to do it.
Discussion Starter #7
So, after a quick look further, it actually just went to the fuse box under the floorboard ...to fuse bank 25. The book says this is for:
"ECU for CAN line interface, OBD, Maserati CODE system, multifunction display"
Any ideas what this could be about?
Discussion Starter #10
Wow!! That's really upsetting!! It'll be awhile before I get her all back together from the matrix replacement, but I'll let you know once I do. 😡😡😡
1) 2fromthe couve: Kill switch
2) CatmanV2: Radar detector
3) tvrv8: Airbag bypass
4) Jason: Mileage killer
5) Stingray71: DBW engage (Warp Factor 9)
6) Timado404(not found?): Ctrl-Alt-Del
Do not flip the switch! The last time we told someone to do that to an unknown switch, he was never heard from again. My team reviewed the situation a few years back, and we concluded that the switch was the "garage door opener" to a wormhole in the space-time continuum. Flipping the switch altered the path of time for the driver, sending him into a parallel universe where all the women were unattractive and the only food to eat was head cheese.
OMG....lmao :ROFLMAO:
7) ErikDiSomma: Stargate
7a)Oishi: Brundlefly teleport pod activation
8)LTchip: Ejector Seat
1 - 20 of 29 Posts
