1 - 20 of 34 Posts
Hi everybody,
Long time lurker first time thread was actually referred here by a good friend Saturn :).
The opportunity to work on this Testarossa presented itself to me when the owners co worker saw some of my other work and referred me to him. I got a call near the end of November from the owner saying that he wanted to get his car detailed for storage.
First off a walk around the bella macchina.
lol yes that is a dog biscuit
In defense of the owner he said it was a while since it was detailed and the last time it was just a quick job
So starting off with the interior I dusted the car down to get in the tight areas. At the time I was using a Meguiars Slide Lock Brush but it gave out on me and I had to take what was left and wrap it in a rubber band, but it still did the job
I then vacuumed the entire car with my Metro Vac n Blo and various attachments to get in the tighter areas
Then gave everything a wipe down with Meguiars All Purpose Cleaner cut 50/50 with water to have a clean surface to work with
Sensitive content, not recommended for those under 18 Show Content
At the same time I used my foam stick to get in the tight areas that my fingers couldn't reach
Got in the tight areas of the prancing horse on the hood and trunk latch and here are some before and afters
Before
After
Before
After
Got in the even tighter areas with a q-tip
Had to scrub a few areas with the fine side of my Meguiars Triple Duty Brush like...
The cassette tape holder buttons
And the "PRESS" on the seat belt
Before
After
Scrubbed the door sill
And the pedals, no dressing was applied after the clean up as common sense is I don't want the pedals slippery
Before
After
Pretty much everything in the interior is leather. So I leather cleaned and conditioned everything... the seats, dash, doors, and roof
Gliptone Leather Cleaner & Conditioner was what I used
Scrubbing away with my leather brush
Leather conditioned by hand and massaged in to the leather
Doors
Seats
Roof
I let it soak in for a bit then wiped off the remainder for a nice natural finish.
Did I mention it was cold!!!
Brought the tool bag, owners manual, and jack inside for a cleaning.
Tool bag was dirty and disorganized
Cleaned up the bag with some APC and the tools as well
Clean and organized (yes I realized afterwards... one of them is backwards. I'm such a hack!!!!)
Leather cleaned and conditioned the owners manual bag
Cleaned the bag that held the jack etc and wiped down the jack and tools
And here they are ready to go back in the car
I took these pics at the final end of the detail but felt it was appropriate to put them here. These are the finished pics of the interior.
Discussion Starter · #2 ·
Now getting started on the exterior I begin with the wheels.
P21s Wheel Gel was used to clean the rims which is non acidic. I could leave this cleaner on the rims all night and no damage to the rim. Acid based wheel cleaners you can't say the same for and even a light application of them to ceramic brakes, anodized rims, etc and a beautiful rim or brake system is ruined. So no acid based wheel cleaners....ever!
Let the rims soak while I attended to the engine bay
I didn't get to aggressive on the engine bay but still did the best I could. I wiped down with Meguiars All Purpose Cleaner and then dressed it with Meguiars Hyper Dressing cut 20/80 with water for a nice natural finish.
Here is a before and after pic
Before
After (still a little wet from the dressing)
Artsy Fartsy
Moving on to the rims
Getting in the inner barrel with my handleless EZ brush
Behind the rim
Cleaned the rim face with a micro fibre mitt
And used a foam stick to get in the lug nut area
Rinsed down the car
And sprayed on Prep Wash to strip off any silicones, which will, if left on hinder the paint correction process because the silicones fill scratches and if not removed the polish will not cut out the swirl but just glide over them
Then washed the car using the 2 bucket method and a natural sea sponge.
The reason for 2 buckets when washing is simple, 1 bucket is only water, and the 2nd bucket is soap water only. After washing every panel or even half a panel you rinse off the dirt from your mitt in the water only bucket before putting it in the soap bucket, there by keeping your soapy water dirt free. Most people use only 1 bucket to wash their car and this one bucket ends up with dirt in it and this same dirt filled soap water is what is rubbed all over the car and in time a perfect paint finish gets all swirled up.
Rinsed my sponge off in the water only bucket after every panel or a half a panel
Dryed the car off and brought it in to clay bar it.
Riccardo Clay was used. The reason for clay barring your paint is it basically sheers out contaminants embedded in the paint. This can be raildust, fallout, or even just tiny dirt debris. If you wash your car and run your hands along the paint you will probably find that it is still pretty rough. What you are feeling is the surface contaminants.
Pretty contaminated
Measured the paint to see what I was dealing with and look out for any low spots. The owner had told me that the whole car had been repainted so I was dealing with fairly thick paint. Measurements were taken in microns which are a thousanth of millimeter.
Masked off the rubber trimmings
And here is what I was up against under 500w halogen lighting
Did a quick test spot to find a combination that worked and here are the results of a wool pad and Menzerna Super Intensive Polish which is a medium cutting polish.
Now for a few before and afters of the body panels
Before
After
Before
After
Before
After
Before
After
Before
After
And a 50/50 shot
Single stage paint really clogs my pads up so I had to change them frequently
All the tight areas my rotary couldn't reach I did by hand with on orange lake country pad and Meguiars M105 then a white pad with Meguiars M205. They did not end up perfect but still a huge improvement to how they were before
This was a full paint correction so the few deeper scratched I wetsanded with Micro Mesh sand paper 2400 grit and then 4000 grit to refine and then finally polish out the sanding marks. Results were either to round off the edges of the scratch to make it less apparent or to completely remove the scratch.
After all the compounding and wetsanding I finally jeweled the paint with a white Lake Country pad and Menzerna P085rd. Here is a shot of me jeweling the paint.
And finally the results of my work
Unmasked the car
Dusted it down and got in the tight crevices.
Gave it an alcohol wipe down to clean off the polishing oils
Then double checked my work with my 3M Sun Gun which omits the same color spectrum light as the sun. So basically what I see with this light is how it will look in natural daylight.
Perfect
Applied Swissvax Concorso
While the wax was curing I attended to some other areas
Sealed the rim with Poorboys Wheel Sealant to protect against brake dust
Dressed the tires with Blackfire Long Lasting Tyre Gel which after being left on for awhile then wiped off leaves a beautiful finish
Here is an after pic of the tires and rim
I couldn't get the exhaust perfect but still made an improvement.
Before
After
Now finally after 50+ hrs of work, -10 weather, and the first snowfall of winter here are the finished pictures.
First up some shots of the sun on the paint
And my last 3 favorite pics.
I hope you enjoyed reading the write up :).
Wes
wow, I didn't see it coming, but that was amazing work!
Any friend of Saturn's is a friend of mine.
I gotta tell you, your cleaning and working on the tool kit got my respect!!!
Wes you kill me. Your so humble. You have been doing this for a long time way before you even knew me.
His work is very professional and the local car community knows of his work.
You should post links of the work you have done on the Porsches, Bentley, Lambo if you were able to take pictures of the process.
One of the reasons his work stands out is due to the Time he spends on your vehicles. 50+ hrs WOW!
For what he charges and time he spends its really a great deal.
People drop off cars the night before or 7-8-9am in the morning. He usually isnt done until 6pm. For cars that hasnt been detailed for years or ever he keeps them for 2-3+ days.
Discussion Starter · #9 · (Edited)
He does fantastic work!!!!
Great job on the Testarossa.
Thanks bro!
Glad you liked it!
Hahaha thanks!
lol I wouldn't even know how to say that all myself :)
Bellissimo!!
Grazie!!
Unbelievable! How does that paint measuring device work? Does it sense the metal and actually knows how much space is between the device and the metal?
And now factor in all the photos he took and the extra time to remember where he was and what he was doing to explain to all of us wanabees....err...in my case, NOTwannabees....Like Don Van Vilet sang in his Clear Spot Album (remember those?!) "Too much time"!!!
Good Gawd, how does my mind work anyways?!? How could I segue to Captain Beefheart on a car forum, no less one specifically about Maserati?!? :269:
The true reason that alot of high-end cars don't have alot of mileage. After putting in that much work to make a vehicle look THAT good, I wouldn't want to take it outside for fear of it getting dirty. Awesome job and writeup on the car and methods. :thumbsup:
Discussion Starter · #14 ·
That's pretty much it in a nutshell.
I couldn't explain it any better.
Thanks, lol only a few understand.
Lol it hasn't left storage since.
Yeah, though I grew up in his era and at one time had most of his stuff on vinyl {until a dirty dirty crook stole all my albums!} I don't know if "understand" is the right verb!! IYKWIM (and you probably do :D) haha.
Are you aware of these guys and their products??:
Zaino Store
You obviously know your stuff. I only send it to you in the spirit of getting (perhaps) equal results in less time and with less effort.
Though I don't do what you do for a living, I've been obsessed with autos, mostly European (Italian of course!), since my first 59 Giulietta Sprint; though there's been a few French {Renault Gordini, Peugeot 504} German (URs4, 4000s Quattro, BMW 325i, Passat TDI) and English (Rover 2000TC, Austin Healey 3000, Triumph Herald, S-Type) pass through my garage.
Said obsession on exterior appearance eventually led me to those guys. They're very accessable {two brothers. One's a chemist genius, and the other a marketing guru} and usually you can query them on the phone, which I did b4 making my initial order back in the early 90s. What's great since then is in around early/mid 2000 they developed the "accellerator" spoken about on their site. Whereas b4 you had to wait at least overnight b4 "layering" on the coats for a more lustrous finish, now you only have to wait 30 minutes or so. Check out their testimonials and photos. And I'd be remiss if I didn't mention you have to totally re-educate yourself as regards amounts used. Their stuff is so concentrated it lasts for years - at least in my case. Give 'em a look!!:cheers:
Discussion Starter · #16 ·
Hey Aprilla,
Sorry for the late reply, but I locked myself in to design my website.
Zaino is great! I used it for sometime and still actually use Zaino Z8 as a quick detailer. But with all these detailing companies always coming out with new and improved things I find myself always trying other sealants, waxes, etc.
Simply AMAZING!!!!
Wes
Just went through your pictures a few times. Simply amazing work! Results are incredible! Your on a different level!!!
I am sure you are very busy. I wish you all the best!!! CM
BEAUTIFUL work my friend.
only someone who Truly loves cars can pay attention to that much detail.
The owner of that car should be proud to have yourself work on it again.
1 - 20 of 34 Posts
