The first thing you need to do is drill a few 1/4" holes in the plastic pan so if it happens again it doesn't soak your EPB unit...Obviously, look where you are drilling... Jason
Are there any unwanted side effects to doing this? Can water get sprayed into this compartment through the holes when driving in the rain? Is the area where the would the water drip out to safe? Are there any sensitive wires or modules underneath this plastic piece?The first thing you need to do is drill a few 1/4" holes in the plastic pan so if it happens again it doesn't soak your EPB unit...Obviously, look where you are drilling... Jason
