1 - 20 of 29 Posts
I am getting some new center vents for my 2003 CC. Getting the infamous "Ferrari" sticky mess on them. Wonder why they insist on using this inferior material? Anyway - just wanted to confirm with someone who has done this that the vents just pull straight out before I put too much force on them (been working out - LOL). I think I read this somewhere here but can't find now - sorry if I am being repetitive. Cheers!
vents
There are 3 tabs on the vents. A small screwdriver can be used to lift the tabs for their removal.I've read oven cleaner has worked magic on cleanup. Or new vents can be had at Trident Parts..
http://www.trident-parts.com/382300802.html
http://www.trident-parts.com/382300800.html
Thanks. I did order them from Trident parts so was just trying to figure out how to remove them without causing any damage. I will look for the tabs and see how it goes.
I've heard this before. What exactly is the 'sticky mess' and what causes it. I haven't seen it yet on my '06 but have been careful with cleaning products in case that's the cause.
From cruising the Ferrari site it appears to be substandard coating on the plastic parts that are affected by air pollutants, finger grease, cleaning materials etc. It is very common on Ferraris and almost all Ferraris seem to be affected sooner or later. There is even a company that specilizes in refurbishing the very expensive Ferrari parts:
www.stickynomore.com
If you have the patience some owners do it themselves with various degree of success. Here is one thread with some suggestions:
http://www.ferrarilife.com/forums/showthread.php?t=7938
As for me, as long as it is under $100 I think I will opt for replacing. Cheers!
vents
The outer vents just pull out with the tabs. To remove the inner vents one must remove part of the dash board.
Discussion Starter · #12 ·
Success! Easier than I had imagined. When you get the new ones you will see the "tabs" and how to bend them back in essence until they break with a small screwdriver. The vent slips right out and then the new one snaps right in - less than a minute. Cheers!
AC vent photos
I am looking to replace my sticky ac vents in my 04 coupe.
I would like to see some photos indicating the location of the tabs allowing for removal of the vents...
any assistance would be greatly appreciated.
dave
3 tabs
With a flashlight look inside each vent.. On the vent wall you will notice the tabs 120 degrees apart.. Use a tiny flat-head screwdriver to lift tabs.If you lift too hard,the tab will break.If you don't want to break the tab you may be able to shim the tab with something .. another screwdriver, a piece of paper, a matchstick.. I think I recall needing to lift the 3 tabs simultaneously.Not complicated at all.If you're breaking the tabs, even easier !! :D
AC vents
from what I have read, it sounds like removal of the two round center ac vents is different from the two side, round ac vents.
can anyone confirm this? I need to remove all four - since they are all sticky.
Alternatively, would a second option be using Qtips with goof off while the vent is still installed?
thanks
dave
ok... Does anybody have photos of the vents out of the dash or a schematic showing an exploded view of the plastic tabs holding the vents in place?
I'll be attempting removal on Saturday and would like to have as much info as possible before i proceed.
please email photos if you have them - [email protected]
dave
1 - 20 of 29 Posts
