21 - 40 of 83 Posts
Discussion Starter · #24 ·
And do you have an error on your dashboard ? -> System not programmed ?
Yes, I have error on Dashboard - System not Programmed - I tried the Italian Reset, removed Battery for 30 minutes - reconnected but same issue. Did you have to program the TMPS for tyres? Can you access teh Tyre pressure display? Was there a setting for TMPS? before I would hit the mode button and scroll to the Tyre Pressure..
I don't have TMPS option on mine. So I can't help you about it. I sent in china a mail to have a solution about 'system not programmed'.
Maye be it's a conflit with CAN Bus. You can see at the bottom, different protocol CAN bus. I tried someone but I don't find a solution
Sorry for my bad English.
Hello,
I wanted to get an update on the information I gave you and if you were able to fix the radio problems.
I sent an email to China to fix the 'system not programmed' problem.
I'm waiting for a return. If you have any information, I am interested.
If I have any, I will let you know.
Discussion Starter · #30 ·
Hello,
Hello,
i did set the settings to Air Dual and Auto Antenna but i get all static, i have pull pull center dash out to validate the radio plug / wire is installed. I had my system installed by a Maserati/Ferrrari service vendor.
Discussion Starter · #31 ·
Hello,
Hello Megaman,
did you have jumpers on your when you first received the Screen? This is how i received mine with some jumpers and trying to make sense of what the jumpers did? Still trying to track down "System Not Programmed" I ran ODB2 scanner for Maserati with no errors or codes listed. I wonder if the jumpers play any role?
21 - 40 of 83 Posts
