Brought my car in for a oil change at the dealership and they happened to come across some leaks and this is what they told me;
Only other notes I have is that there are two small oil leaks. The left and right side turbo oil return lines have small o-ring gaskets leaking, and also the front engine cover is leaking as well. The left and right side turbo oil return lines have small o-ring gaskets leaking, and also the front engine cover is leaking as well.
The cost to replace the 4 o-rings on both sides of the turbo lines is $520 plus tax. The front cover is very labour intensive, it comes to $5,950 installed.
Has anyone else had similar problems with leaking o-rings in the turbo oil return lines or the front cover. And its not the valve covers they are talking about apparently its a cover in the front thats leaking thats behind the rad.
