Does anyone know which fuse and the wiring run for this. The light was out, changed the bulb- nothing -and then checked the power - zippo at the wires. Can't seem to find which fuse to check - and I believe it's on a fuse with other lights and since nothing else is off tells me its probably a wiring issue.
TIA
Is there a relay to check ? Also, can't seem to find the switch that turns it on when the trunk is opened.
TIA
