Jonesin82
Discussion starter · #1 ·
So my traction control suddenly not turning off. Is there a way to bypass it. Didn’t know if it was bc myOdometer is blinking? (Yes aftermarket radio but it’s been in there several months.). Also my seat heater comes on ever though it’s set to Zero. Thank you.
1) When you say: Not turning off, what's actually happening?
2) Seat controls get water in them from the roof. Sometimes contact cleaner sprayed in and the control operated several times can help
Discussion starter · #3 ·
So I fixed the blinking odometer it was the fuse that controls the steering wheel controls and the ASC TRACTION CONTROL. The fuse it self looked good but but after trying everything, I decided to take every single one of them out and test continuity on them and sure enough it was blown, but it didn’t look like it. That restored all that just FYI, for the future, anybody reading this?
however I still have the issue with my heater is turned on randomly, but it shows on the dash and on the little wheel on the seat in position zero. Not sure what to do or think about that. I’d be fine with it if it was winter. Thanks for the tip. I will try that when I get home plus it has stopped, allowing the backseat easy lever control access. Thanks again.
