the label says 29 psi cold tire pressure.
what tire pressures are you guys running your QP at?
i find 29 psi to be way too low... i run 35 psi cold..
I have the 20" sport gt wheels... Recommended is the 32/29psi... Going into summer here so 60F-100F for 3 or 4 months..
245/35/20, 32psi I also think it's a bit low I'm going to try 35psi.
295/30/20 (supposed to be 285), 29psi seems to be too low also. When I take a turn from a dead stop I get a little bit wheel hop for the rear tires. I was also thinking since the rear tires are 295 instead of 285 maybe I should put more air than the recommended 29 psi. I'm going to try maybe 35 PSI for the rear 295 tires. I know there are couple guys here that run 295's on the rear I'm curious to see what PSI you guys use. Considering that The 29 psi is meant for it to 285 tire.
So if anybody can give me a little advice on what I should do considering my current situation.
245/35/20
295/30/20 (I think this should be a little higher considering the tire is bigger)
Temp 60F-100F.
Try to avoid we'll hop on turns with the rear tires.
