Hi folks,
The scene : 5 AM early start, (very) cold and foggy, had a 150 mile journey ahead, prepared for the ride as usual.
Start the car, no probs. Turn on the heating for a windscreen defrost, and prepare to reverse down my driveway. Hummm, not quite hot, well, not at all hot, WTF..? Check on the instrument panel, outside temp marker and E sign flashing intermitently. Oh no... Turn heating off, E flashing sign dissapears, outside temp seems to hold OK. Drive for 1 mile, try again, E sign reappears, fan working, but obviuosly throwing cold air inside.
End result: travelled to my destination in an almost frozen state, had no option :mad:
Has anyone experienced this one before? Of course, it's the first usage of the heating since the last winter, but who knows... maybe resetting through the battery switch?
Any ideas/suggestions greatly appreciated.
TIA,
Ed
Cold enough for me and for the windscreen to be iced... I had to go with 1 window open to avoid condensation, and cruising on the motorway... agree not as cold as, e.g. some parts of Canada (been 3 months in Edmonton in winter... that IS cold) or Minneapolis, but uncomfy and not the sort of morning to be driving as if in a Spyder.
I've had this happen with a LowBat warning. When the electrical system senses a voltage drop one of the first things it cuts out is the climate control. Particularly on cold days - high load situations (dark & defrost on).
After driving a bit you should see the voltmeter move back into the normal range and the LowBat warning go out. Things should then get back to normal.
I have also had it happen once. The manual said that the E was an indicator that the AC/heating system had malfunctioned. In my case, it disappeared the next time I started the car and hasn't reoccured for several months.
Just part of the charm ....
Mike
Cheers Steel... but think that's not quite it, as the battery charge was very healthy indeed, and tried again a couple of times whilst on the move. A friend suggested the actuator might be stuck, but then I used the aircon over the summer (and the actuator should work both ways, both for cooling and heating, and the aircon worked just fine).
Thanks for the feedback. This + the 9ers display yesterday made the start of my week just fine...
