1 - 4 of 6 Posts
Xynactra
QP 4.7S 2010
Discussion starter · #1 ·
Hi!
I have replaced both TGK Valves because they let coolant flow trough even if i set 16°C.
The new ones worked for like 1 hour, now they do the same.. is there a relearn procedure?
The old ones were definitive leaking, i tested them in closed position and could blow trough. On the new ones this was not possible.
Best regards, Nico
Discussion starter · #4 ·
I read online and found a post in a ferrari 559 forum. They said, disconnect battery and reconnect would fix the problem.
I did it today and well.. it fixed the problem 😆
1 - 4 of 6 Posts
