1 - 16 of 16 Posts
2006 QP
on my way to get my T-lever fixed, tried starting the car
it wouldnt so i jumped it from the battery terminals in the back
before all that i when i tried to start the car the 1st time, theres a light that is showing on the gauge cluster 'system not programmed' airbag not programmed and an XCLAMATION???
what gives how do i get rid of it???
any info would be greatly appreciated
thanx
'system not programmed" is because of the warranty start date, however I find it odd that you have not encountered this before on a 2006 model.
The airbag light is from the battery dying or discharging to the point that the airbag ECU can no longer stay alive, Go to the trunk and disconnect the NEGATIVE battery cable (the one closest to the taillight) and leave it off for 5minutes then reconnect, the airbag ECU should reset and the light should go away. Best of luck.
1 - 16 of 16 Posts
