I know this is an old thread, but...
Has anyone else experienced problems starting after re-fueling?
I've had trouble starting my 03 Coupe GT every time I re-fuel (I just purchased it, so it has only been 4 times).
It takes 2 to 3 times to start, then runs rough for about a minute after it does start.
I was wondering if it had something to do with losing the vacuum after openind the tank, so here's what I've tried so far:
-I have made sure each time the gas cap is on and secure
-after refueling the last couple of times, I turned the key to ON for about 30 seconds before turning the key the rest of the way to START. It still took 2 or 3 times to start the car.
-after re-fueling, I drove home and turned off the car. Then I opened the gas cap and left it open for a couple of minutes. I even pushed open the flapper valve inside the opening at the gas cap. Tried to start and it started with no hesitation.
The only thing I haven't been 100% sure I do is turn off the car before I press the button to open the door to the gas cap before I turn off the car. I do know that I haven't opened the gas cap before turning off the car.
So....I'm baffled as to why it won't start when I actally refuel, but it doesn't have any problem starting when I open/close the gas cap without adding fuel to the tank.
Any ideas?
