I recently acquired a 2003 Spyder Cambiocorsa with just under 20,000 miles and have been delighted with everything about the car except its occasional but alarming slippage into Neutral gear.
There does not seem to be a pattern to the slippage-it's happened more than once while stopped at a traffic signal, and once while driving along at 40 mph. In each case I was unable to shift into forward gear without shutting off and re-starting the car.
Before posting this thread I searched the postings dealing with the CC trans and found I'm not the only owner to have experienced this problem, but for the others it seemed to have only happened once or twice. The sole solution offered seemed to be "make sure the hood is securely closed", which I've done.
Any other suggestions to cure this problem will be most appreciated.
