1 - 15 of 15 Posts
If one would not be tracking the car but using it as a "frequent" driver....
Skyhook...is softer or harder than the "standard" uspension?
I must pull the trigger tom'w (march 31st incentive) and I have found a truly beautiful car outfitted exactly as I want but without the skyhook....or do I compromise and go for the skyhook car?
thanks in advance,
Eric
I would go without Skyhook. Skyhook is useless to me as I depress the Sport button all the time anyways which makes it as tight as a non-skyhook car. With the sport button off, it rides like a Lexus. The only adavantage to the Skyhook is the ablility to lower the car without a great expense.
If you want to track the car and are willing to dish out a couple of grand on an aftermarket suspension then the Skyhook is not for you.
When I was first shopping for the car (before I bought my m5, three years ago) I was dead set against the skyhook becuse I wanted the pure feel of standard springs. I now own a skyhook car and I'm happy for it. The only report of a non-skyhook car I've seen says that the suspension is poorly sorted. On my car, the standard setting (soft) is actually soft to the point of being floaty at times. The sport setting is VERY stiff. The end result is a whole lot of toggling between standard and sport on my part. I'd guess the standard suspension is somewhere inbetween the two settings. I'd get the skyhook if I were you.
Hi,
If you have already found what you were looking for "...a truly beautiful car outfitted exactly" as you wanted. It does not matter much if your car comes with/without the skyhook, each option has its pros and cons and since you will not be tracking the car at all. But you will have the best of both worlds in the skyhook option as an innovative technology in your ride. Get the car before the next discerning buyer purchases it and become an instant Maserati owner.
Cheers
thank you all for your input.
I have it narrowed down to:
Nero Carbonio GT with skyhook 18" wheels..(Las Vegas)
or
Bianco Fuji CC with sport interior non-skyhook 19" wheels (S.F.)
some of you may know the cars in question...
I am now leaning towars the GT...
I have a few hours before I must make my decision...
My impression of non-Skyhook is that it is as stiff-riding as a Skyhook on Sport mode. I think that there is about the same lateral sway as well, but a lowered Skyhook has less dive or squat with braking and acceleration.
Keep in mind that I have a GT non-Skyhook car. I had a local Porsche Cup driver shake down my car and he did not think it would benefit from larger sway bars. He thought that lowering it a couple of cm and coil-overs would help. He also thought that 19 in wheels would add weight and little else.
What would really would help is losing about 500lbs.
My experience in a CC Skyhook car is about 200 miles. It was lowered about one inch with factory 18 in wheels.
1 - 15 of 15 Posts
