Since I pick my QP5 ex-owner did change active suspension to KW-V3. I guess everyone will expected direct shown on dash with warning light for
"Shock absorber failure". By theory CAN system would frequency pulse check with current feedback by the magnetic coil from skyhook absorber, than I would like to bypass this signal with resistance. Cause I never hold any skyhook absorber since I pick my QP5. Could it be anyone help me measure the original absorber magnetic coil internal resistance?
You can buy a device that plugs into your now empty skyhook connector. You will need 4.
I knew that KW provide a kit set for bypass. But it is huge different of cost. If can do by ourself why need to give unnecessary waste. (May be finally couldn't success but worth to try just few dollars trial.)
Discussion Starter #5
Check Formula Dynamics. They sell a set maybe cheaper than KW.
"Optional Skyhook Error Cancellers + $550" from Formula Dynamics. Almost same price as KW set.
