1 - 9 of 9 Posts
I've spoken a bit with Jeff from Formula Dynamics about the x-pipe from Larini... I currently have Tubi boxes on the rear exhaust, but wondering if the x-pipe adds much. Also, need to make sure it doesn't push the noise level too high.
Has anyone had experience adding the x-pipe to their stock exhaust, or adding to any other exhaust, and gauging the difference in performance and noise the the x-pipes themselves make when adding (by themselves) to the system?
Thank you,
Vendor
Larini X + Tubi boxes.
...Jeff's link is dead-on! After 6 months, I LOVE this mod. as much as anything I've done,: excepting the springs. And, after adding the X-pipe and Tubi boxes, the HP dynos at 412! No chip or other mods. except BMC air filter and Denso Iridium plugs... It is loud (peolple look) but God, I do love it so!!:D
Moderator
Wow!!!! Can you post the printout? The car should dyno around the low to mid-300s. If you are getting dyno readings at 412, either they dyno is off or you have a very well modified engine.
Could anyone here tell me what the net result is if you got the X pipes ONLY and not the whole muffler?
Most agree mufflers are the way to go if you only want to change one thing. Here is a great recap of options from Jeff...
http://www.maseratilife.com/forums/showpost.php?p=38451&postcount=6
The 412 number sounds about right if it is drive train loss corrected (e.g. dyno result at the rear wheels plus 15% to estimate an equivilant crank HP).
Assuming that the manufacturers advertising can be believed, the Tubi exhaust and the X Pipe together should add about 20 HP to the stock 390 (measured at the crank). This would equate to about 350 HP measured at the rear wheels (assuming a 15% drivetrain loss).
Larini X pipe only.
Hi, i just put on the X pipe only on my QP and i have to say, its quite a big differance. there is a lot more resonance and you get a howling F1 sound from 3 to 4 k rpm, the raspy Ferrari 360 sound and sharp backfires only happen when your apply some load on the throttle, if not, its just louder and lower. I like it, was not expecting this much more volume but it really sounds nice when your going for it.
Vendor
xxxpres, Glad to hear it worked out for you. Let me know about those Ferrari meets!
-- Jeff
1 - 9 of 9 Posts
