Have any one ever had there rubber seal around the doors rip or tear, I have had that happen to my 06 GS, and I'm not sure if this is a freak accident or something that happens frequently?
It should be about about $500.00. Mine is torn as well and I called the parts dept to get a quote.See this http://www.maseratilife.com/forums/showthread.php?t=7113
The '03 Spider I just bought has a small tear in the driver side gasket, for now I'll just fix it with some silicone gasket sealer as the replacement gasket is $1,700 from the dealer.
Mine is coming off by the front of the driver's side kickplate. One member suggested I pull it forward and then try and push it back in but that didn't work. The dealer's 90 mis away so any other suggestions are appreciated.
Thx did you see how they pushed it back in? I have tried by hand to just pull and shove it in there, I'm in pretty decent shape and I can't seem to force it in. Did they use a tool to push under the kickplate?Same problem about a year ago. They touched a bit of adhesive to a few spots and pushed it back in. You can most likely do this yourself. took the guy at the service center literally about 30 seconds.
Aft edge???? was it port or starbord?Back a year or so ago, my rubber trim around my windows tore (aft edge at top). Happened to both sides.
Dealer stated the windows were maladjusted from the factory. They adjusted the windows under warranty and replaced the rubber under warranty.
I was told the rubber was expensive so see what your dealer says.
