I was curious as to what is the RPM at idle for the QP. I ask because it seems to vary which I would expect depending on whether AC is running etc. However I have noticed something which I can't explain.
The background is that as per previous posts, I will occasionally shift into neutral and coast / brake when arriving at a stop light or sign. Let us ignore for the moment whether this is advisable or not e.g. does it prolong clutch life or is it safe. When I do this the car comes to a stop with an RPM of 1000. If while at a stop and in neutral I tap the gas, it drops to 800. Is there an explanation for this? And / or what is the specified idle RPM for the 4.2L engine? Is this set by the mechanic or does the ECU "dial" it in?
