1 - 20 of 37 Posts
I just purchased the Autel 200 OBDII and hooked it up to my 2018 Granturismo Sport. It was simple and guided me as I went using my Samsung phone. It pretty much walked me through the steps and took like 10 seconds to connect. All I did was run a scan and it worked. I am getting ready to change the oil in the next couple of months and I saw a review on You Tube that said it would work on Maserati of all types. It is supposed to reset the service light. We shall see when it comes on. I think it will. I thought it was worth a try for $50 on Amazon. Anyone else tried this one? See Link: Amazon.com: Autel AP200(HT200) Bluetooth OBD2 Scanner, Code Reader with Full Systems Diagnoses and 19 Service Functions, Mini Size Version of MK808 Diagnostic, Vehicle Scan Tool for iPhone & Android Devices: Automotive
I hope it does reset the service light, so please report back... FYI I bought the Foxwell NT530 and paid a little more for it, but unfortunately it did not work. It does read most codes and resets some of them, but the service light ain't one of them... I suspect the only ones capable to reset the service light are the professional ones that will cost you $$$
Thanks for sharing and good luck!
According to others on the forum, the OBDSTAR X-200 will reset the service light. It is on Amazon for $219.
https://www.maseratilife.com/threads/obdstar-x200-pro.111505/#post-877713
If the Autel can do it for $50 that is even better, but we'll need to see the result when someone tries it.
OBDStar X200 Pro
Yes the OBDSTAR X-200 will reset oil service light, at least it did on my 2014 GT. Sold mine here, last year. I wanted something with more functionality and more user friendly. If all you want is to reset Oil Service/Wrench Light, the OBDSTAR will do just fine.
If you immediately want to know whether this works, you can change the system date in the Mas to a future date sometime after the expected service wrench appearance, which should then elicit the "wrench light." Then try the Autel.
Just remember to change the date back to today.
Discussion Starter #6
I actually scanned the codes and that worked great. Had a couple on stuff like something to do with passanger door etc, and it cleared them all out to pass. I also went to service section to look at where I will clear light out and it has a place to reset oil light. This is the video I spoke of in original post.
Discussion Starter #7
Here are screen shots from my phone.
Discussion Starter #8
The top of first photo is just an advertisement for Maxi CV or somothing. Not part of working app.
The OP is referring to an Autel which is a totally different animal than the obd.
Discussion Starter #11
Autel AP200(HT200) Bluetooth OBD2 Scanner is what I bought on Amazon. It is what I am referring to.
Posts #3, 4, and 9 were referring to the OBDSTAR X-200 as a different option in case this Autel did not have the capability to reset the service indicator.
Discussion Starter #13
Got it. Makes sense. I hope the Autel works.
From the reviews I've read, you have to pay an additional $15.00 per year for each brand of autoto continue the software license.
Discussion Starter #16
Yes, when you set it up, you get the first auto free.(Included in purchase price.) If you add other autos, the charge is additional. The cool thing is if you have 10 cars, it will supposedly work on all. You just have to pay for each additional one. One car is covered though.
Thanks, but there is an annual renewal of $15.00 for each car, am I correct?
P.S. Why don't you set your system clock forward and try resetting the wrench; the community will love you for this.
Discussion Starter #18 (Edited)
I think it is just for additional cars. The first/original is included in purchase price for life. That is my understanding. I'm not resetting date because I am afraid too. I pluged it up when I got it, looked at the codes, reset a couple of minor ones that had been thrown and shut it down. I then got brave, plugged it back up and looked at where you would reset oil light. I saw how it would be done and feel good about it. Turned key off, unplugghed it and put it up. I am not brave enough to mess with it until the light comes on. I will then try to turn it off. If it works great. If not it only put me back $50. I will then try to rent or buy the OBD Star.
OBDStar X200 Pro
FYI, just got the OBDX200 from [email protected] following the tread you posted. He charges $25 to rent it, and it does work (very easy to reset).
Thanks!!!
I recently purchased the Autel 200 OBDII on Amazon as stated above (great deal by the way). I can tell you that yes it does reset the maintenance interval light on my 09 QP S. I was actually a bit surprised by the features as it tested and diagnosed all of the vehicles systems (nodes) including our favorite Skyhook suspension system which has been giving me a Check Suspension message for a month. Code for R front accelerator sensor. Verified and soon to be replaced.
1 - 20 of 37 Posts
