1 - 13 of 13 Posts
Hi all,
This is another "old" topic but I figured it would not hurt to summarize what I did for the benefit of the community.
My car came with two keys. However, one of the keys was the red valet key, which does not have a boot release remote button and does not open the glovebox and the boot . So I always wanted to get an extra "regular" key for peace of mind.
Moreover, the alarm fuse was pulled and the alarm (and remote locking/unlocking functionalities) was not functioning. I do not care much about the alarm but I wanted the convenience to remotely lock/unlock the car and the boot. I did some debugging but because none of the remotes that I had was working, I could not use the remote re-learn trick (lock-unlock the car several times until it stops operating the lock and then quickly press all the remotes to pair them with the alarm ECU).
Therefore, I had to (1) duplicate my "regular" key and (2) reprogram the alarm. The final product unfortunately was not as "clean" as I wanted because I ended up with three different keys and non-integrated remotes but at least now I have a fully functional spare and all keys have functioning remotes!
The keychain was tailor made by an Etsy creator. I will be happy to hook you up in case you want one made (I edited the 4200 profile myself).
Car alarm Font Material property Gadget Rectangle
So, on with the details.
First, duplicating the key. To open the car and start it, all you need is a blade cut to the right shape and an immobilizer chip cloned off a working key. I ended up getting a blank key from member @Andrew1211 who made a blank 4200 key out of a Granturismo key fob (the electronics is unusable for the 4200 and I understand also the blank blade is different between the two cars). However, if you go to a good locksmith I am sure they can source something compatible for you (perhaps without Maserati insignia though). Since Andrew already did the legwork I found it convenient to simply get the key from him.
For the duplication, I went to a local locksmith with my original "regular" key and he cloned it in a few minutes. In case you have the tools, the immobilizer uses chip ID46 if I am not mistaken. I am not sure about the key blade.
As for the alarm, reprogramming it requires special tools which as far as I know are not common. I decided to ship my unit to Abacus Alarm UK as their price was more competitive than ECU Doctors here in the States. Abacus was a pleasure to deal with, and the turnaround was very quick (not considering the international shipping times).
Unfortunately, Abacus discovered that my regular key fob electronic board was toasted and this is why I had to buy a remote fob also for my original key. That was a bit of a bummer as I had hoped to have a fully functioning stock key. Unfortunately, Meta (the alarm maker) does not make the electronic board any longer, so the only alternative is to buy a used key and hope that the electronic board is good for a transplant. Current pricing for used key is too steep to justify at the moment so I just added a key fob remote.
For Abacus to re-program the alarm, I had to send the alarm ECU and the key fob electronics (one of which turned out to be faulty as I explained).
Automotive lighting Font Auto part Gas Rectangle
The alarm ECU is under a panel on the passenger left side. Since I have not seen good descriptions for the 4200 I will show some photos here of the process.
First you need to remove the rear seat back. Procedure for this is documented in the thread below and in many others.
Next is the trim above the speaker. This is held by clips and you need a hook trim tool to be inserted on the left side (there is a small access cut) to take it out. Place some electric tape to protect surfaces. Simply pull out to undo the clips.
Automotive lighting Hood Automotive design Motor vehicle Automotive mirror
The trim will expose three screws. Take them out and slide the top panel up, forward, and out. The panel has two tabs at the bottom, mine were taped with paper tape. Not sure if this was somebody else hack or stock.
Tool Automotive tire Gas Scale Bumper
With the top panel out, you will have access to three screws that hold the bottom panel in place. Be careful that the screws have a small metal sleeve that can easily fall off as you take them out.
Vehicle Car Motor vehicle Automotive tire Hood
The lower panel has two clips at the bottom that you have to pull out. You could remove the seat bottom for easier maneuvering but you don't have to.
Automotive tire Vehicle Automotive lighting Automotive design Motor vehicle
Now with everything out you can finally take the alarm ECU off. Sorry I did not take great photographs but it is straight forward. You remove the three nuts and then you slide alarm ECU from underneath the panel (you have to slide the three studs off the panel, down and then out, as the ECU is bolted on a bracket that incorporates the three studs that you see protruding in the photo below). The black component that you see in the photo I think is a motion sensor or something to that nature. Its bracket will come off as well but you don't have to do anything with it.
Hood Motor vehicle Automotive design Trunk Car
Once you get the reprogrammed ECU back from Abacus Alarm you simply plug it back in (I did it with the battery disconnected but I was not given special instructions) and the remotes will magically start working again!
Thanks for posting this, I'm in the same boat, 1 key and an alarm that has it's fuse pulled. Here's a question did your trunk button in the glove box work when the alarm fuse was pulled? That button and the inside door locks don't work on mine. I'm hoping fixing the alarm fixes those as well.
Mmmhhh, the glove box trunk button worked for me.
Tomorrow I will check which fuse was pulled and let you know. Perhaps you have a different fuse out or two of them (one for the alarm and one for the central locking system).
Tomorrow I will check which fuse was pulled and let you know. Perhaps you have a different fuse out or two of them (one for her alarm and one for the central locking system).
Darn I'd hoped it was the alarm, I kinda checked most of it, guess I'm going to have to go over it again. Well at least know I know the alarm won't solve that problem. Thanks for the reply I learned something tonight.
2006 Gransport LE
Thanks. So much work to get a spare key. I worry about this all the time as I only have one key. Wish there was an alternative.
In my car, fuse #33 was removed. Without this fuse, the trunk button in the glovebox worked and when I opened the door with the key it unlocked also the opposite door.
Have you checked fuses #29 and #40?
Rectangle Font Parallel Slope Diagram
Font Parallel Rectangle Screenshot Number
I see also some trunk related relays and fuses in the trunk that you may want to check.
Relays #A, #E, and #H
Fuse #9
Product Rectangle Font Parallel Design
Rectangle Font Parallel Number Screenshot
Font Parallel Number Screenshot Document
Discussion Starter · #8 ·
Well, if all you want is a spare key (no alarm functionality) if you go to a locksmith they should be able to clone yours with a generic looking key that will open the doors/trunk/glovebox and start the car.
If you want a Maserati looking key, then you have to assemble your own off a Granturismo type key (which is what Andrew did).
If you want also remote functionality, I believe that if your alarm is currently working, you can simply order a FOB and program it your self using the lock/unlock sequence with the working key FOB.
Discussion Starter · #11 ·
Maserati will sell you one.....
Actually, you raise a good point. I did not even try to go to a dealership based on the various horror stories that I have read: I remember reading more than once about dealer ordering a $600+ key and then be unable to properly program it for the car.
However, I think best practice (which I did not follow!) is to go to a dealership first, inquire for a new key and have a clear discussion upfront about their capability to actually make the key work. I think that if the alarm is currently not working, most dealers won't be able to reprogram it and will always advice for a new alarm (which is expensive and the reason why I did not even try this). If the alarm is functioning, then I think that even if the dealer fails at programming the key, any locksmith will be able to clone it (blade cut and immobilizer chip programming) and then you should be able to use the lock/unlock procedure to add the key remote to the alarm.
For reference and comparison this is what my costs were:
Blank key - $105 (I am sure you can get a cheaper one if you don't mind about the look or if you put it together yourself)
Key cutting and immo programming - $180 (Locksmith saw a Maserati and charged me more saying that this could turn out to be a difficult job and bla bla bla... I tried to push back but I was there and I wanted to get it done. In different markets you can probably get this done for less than $100, which is what I should have paid!)
Alarm reprogramming: Abacus charges about 200 British pounds. Each key fob is 50 British pounds.
So I still spent a lot more than I wanted but at least I got everything functioning without wasting additional time.
Nice write up!...Jason
Thanks!
· Super Moderator
Yes, this is true. If the alarm / central locking is not working with a current key, a new key is unlikely to help. Any dealer should be able to program a key to the ECU to make the car start though.
The 'problem' if problem there is with cloning keys is that if you lose one, you cannot remove it from the system. So there's always a key out there that will start your car. Not a biggy in the grand scheme of things, though.
I would like a new key for my Ghibli but services here in terms of cloning seem rather less advanced than across the pond
Discussion Starter · #13 ·
You are correct. However, if it gets to that, I think one can always properly add a new key later, remove the lost key immo memory, and reprogram the cloned key.
Also, YouTuber Samcrac recently made a video showing an aftermarket tool that can properly program keys. Topdon was the make.
I could have shopped around a bit more for the locksmith and found somebody with that kind of tool to try to properly program the key into the ecu immo memory.
1 - 13 of 13 Posts
