1 - 14 of 14 Posts
I have new QP Sport, 6500KM. Engine light just came on. Is there an OBDII scan tool available which will read the codes, and if so, is there a key for the codes! Lastly, would I be able to reset the light myself in case all it was was the gas cap was loose. I assume that if it were something else then the light would come back on and then I would go to dealer. I have seen similar threads, but they seem to be regarding older vehicles.
Thanks in advance.
Innova equuis 3110 or higher will read maser codes and allow you to reset...most likely a loose gas cap threw an EGR code
The Innova unit translates the codes into the problem as well (ex. 22304 Misfire in Cyl X) so you dont need a translation key
Innova scanners are about 125 shipped on ebay
Scanner must have OBDII and CAN abilities
Thanks for the info. I had read about this tool in other posts, but I didn't know if it worked for the newer 2007 QP. What does the CAN refer to? Is there any point in getting a higher model number, e.g. the 3140?
Regards,
Craig
Regards,
Craig
I Googled the product name and found a web site with tech data. There were four models offered, I ended up buying one for about $170.00.
...What does the CAN refer to? Is there any point in getting a higher model number, e.g. the 3140?...
CAN data transfer protocol commonly found in cars.
http://en.wikipedia.org/wiki/Controller_Area_Network
ODBII (On Board Diagnostic) is yet another data transfer protocol (ODB is the first gen)...anyhow, it's a standard required by the US EPA...not car specific. Not to mention model specific. Though, some auto manufactures don't conform to SAE standards...
Well, based on advice, purchased an Equus scan tool. Of course, while I was in the store picking it up, when I came out to the car, the light no longer was on! Anyway, I found the OBD port for the QP on the far right on the drivers side (Panel you need to remove is actually marked by stitching "OBD" into the leather.)
Does the following mean anything to anyone, and in particular, do I need to act on int?
Stored:
P000A Engine Position System Performance - Bank 1
MIL OFF
Misfire Monitoring Complete
Fuel System Monitoring Complete
Comprehensive Component Monitoring Complete
Catalyst Monitoring Complete
Heated Catalyst Monitoring Not Supported
Evaporative System Monitoring Complete
Secondary Air System Monitoring Complete
A/C System Refrigerant Monitoring Not Supported
Oxygen Sensor Monitoring Complete
Oxygen Sensor Heater Monitoring Complete
EGR System Monitor Not Supported
DTC for which Freeze Frame was Stored P000A
Fuel System 1 Status Closed Loop
Fuel System 2 Status Closed Loop
Calculated LOAD Value 43.53 %
Engine Coolant Temp 84 °C
Short Term Fuel Trim - Bank 1 -8.59 %
Long Term Fuel Trim - Bank 1 -7.03 %
Short Term Fuel Trim - Bank 2 -7.03 %
Long Term Fuel Trim - Bank 2 -7.03 %
Engine RPM 1953 rpm
Vehicle Speed Sensor 27 km/h
Ignition Timing Advance #1 Cylinder 27.00 °
Intake Air Temperature 30 °C
Air Flow Rate Mass Air Flow Sensor 34.41 g/s
Absolute Throttle Position 18.43 %
Commanded Secondary Air Status Atmosphere / Off
For a given octane level no but for 91 to 94 there is a big difference...My Coupe HATES 91 and I have recieved similar engine codes because of it...the short term fuel trim on bank one not being in line with the other trim specs shows that something is up either with the fuel or the fuel delivery system...since she is brand new I would lean toward fuel first.
Discussion Starter · #10 ·
Will try 94 for a few tanks and see if it recurs. Do you think I can safely erase the code or should I leave it for dealer to check out when I take it in for first service?
go ahead and clear it...that way if it happens again you will know that it is a new error code not the one you have already checked
interesting that the code popped at such a low RPM the only times I have recieved that message was along with a misfire code on my CC never just by itself
p000a
I am just having the same code (p000a) randomly popping out, so I was wondering if you ever resolved that issue. Any help would be appreciated.
Thomas - 2007 QP Sport GT in Poland
Stored:
MIL OFF
Engine RPM 1953 rpm
07 QP Sport GT auto - 80K miles - 93oct - 2K-3K mile oil changes - Daily driver
I went into a store yesterday, car was running perfect.. When I came out and started it, it made the usual variator noise i have, but then started to run HORRIBLE right away ... shaking, "sounded" like it was trying to stall but it wasn't. I clearly hear and feel it driving under 20mph.. after that the throttle smooths out as if nothing is wrong.. but when i come down to 20 mph again its there. At a red light it sounds the worst.
Turned car off and back on couple times, disco the battery overnight etc. No fix.
Strange part is, I'm not getting a CEL at all. Nothing negative on dash at all. But I did plug in the OBD anyway just to see and got this.. Stored: P000A Engine Position System Performance - Bank 1
I will be changing spark plugs soon, but I doubt that's the problem. For some time I've been getting code P0128 which is the thermostat I believe. But that code pops up every month or so and I clear it. I honestly thought the variator issue finally caught up with me and was starting to kill the car. Any advice?
· Vendor
P000A is a warning about your Cam Variators having a slow response, we wrote a bit about it on your other thread, hope it offers you some help!
1 - 14 of 14 Posts
