I was hoping to upgrade my 2007 QP Sport springs with the Formula Dynamic group buy. I have since learned that the coil over shocks in models after 2006 do not have an adjustable lower perch
I know I could use a fixed height spring (is there any available?) but I would prefer to have adjustable as I don't know how much I want to lower car and would like the option to adjust as needed.
I am thinking an option might be to use an adjustable coil over sleeve. I am not sure if that would work, and if it did, what specs I should look for i.e. diameter of sleeve etc.
Also, I am not sure if the fixed perch on the skyhook shock is flat and therefore would accept a sleeve, or if the lower perch is angled or indented on top to accept the end of spring such that the lower end of sleeve wouldn't sit flush on perch. I have attached picture below in hope that someone might be able to at least answer this question. Any advice would be welcome.
