1 - 8 of 8 Posts
As I find that the original brakes is soft and also the pads has wear out. I am exploding the option to have it replace with other performace pad ike EBC redstuff. Any body have change to any other performace brakes pad. Please give feed back. Thanks
If you carefully lift up the Brembo sticker on the pad you should find the OEM part number. That will also provide you with a cross reference you can use.
What's this about color? I knew there were different caliper colors available, but were the pads colored as well (I assume just the metal portion if at all).
Discussion Starter · #8 ·
Guys, sorry for the confusion. I am refering to the caliper color Red. The brake are ordinary black color. As the red color caliper are also biger in size I assume that the pad should also be bigger.
Have talk to Jeff from Formular Dynamic and are placing order for the formula dynamic pad. Also with their DBW and ECM.
1 - 8 of 8 Posts
