1 - 3 of 3 Posts
Quattroporte V 4.2 400
Hello,
my mechanic changed the Electric Parking Brake Control Module on my 2007 QP (Part 229384 replacing 281371). The play is a used play. Once the part is in place, nothing happens while with the old part the brake is put on once and then breaks down.
I would like to know if there is a reset of the brake system or a learning to do so that the new part is seen?
Thank you.
I believe there is a learning process, yes. I assume your mechanic does not have the correct diagnostic equipment, or he'd know this?
He does have the TEXA diagnosis, which is well known. I will check with the TEXA provider for information.
Thank you.
1 - 3 of 3 Posts
