1 - 2 of 2 Posts
I've been having a few issues with the car so I've been hooked up to the scanner a bit lately.
I just returned from a spirited drive and sat in the driveway for about 15min finishing up a phone call.
The car was idling the whole time.. just sitting. After the call I looked at the scanner and it reads my intake air temp at 154 degrees.
Isnt that kind of high? Its 50 degrees out today, and the coolant temp was normal, around 190 Degree
Where should that intake air temp be?
Yes, that looks high..The air intake should be pretty close to the actual temperature..I might try another scan tool to make sure the data is correct before I start getting into it....Jason
1 - 2 of 2 Posts
