21 - 37 of 37 Posts
$35.99 go to you local auto part store and ask for pads for a 20 10 camaro ss. They have the same caliper and match the pads. The only issue is the don't have the slot for the sensor.
hi . i am working on 2002 spyder 4.2 just wanted to ask if anyone has cross reference for expansion valve .oem part # 375530166
Parking Sensor same as from Volvo
Repaced yesterday the Front Parking sensor on mine QP 2005 with a sensor from Volvo , works as a charm!
Cost in the Netherlands € 40 aprox 42 dollar
Volvo S/V70/V70XC 2005 - 2008
Volvo S40N 2004 - 2012
Volvo S60 II 2005 - 2009
Volvo C70 II 2006 - 2013
Volvo XC90 2003 - 2006
Volvo S80 II 1999 - 2006
Volvo V50 2004 - 2012
Oreillys auto parts which are the Brake Best Select premium the part number is SM1053 and the Duralast gold from Autozone is DG1001.
no place for brake sensor though but fits perfect.
Autozone DG1001 does NOT fit '09 QP base rears, but DG1053 does. Has anyone found a local pad for the fronts?
MAF sensor QP
If somebody needs MAF sensor to replace good start will be to buy insert only without housing. In my 2005 QP is F00C 2G2 044 bosch and could be found in various models of Fiat stilo, Alfa 147/156 petrol and diesel engines from 2001 onward. Italians changed a housing only and use the same sensor for 1.9 JTD 8v 116 hp and quattroporte 4.2 400 hp.
Not sure for restyle QP or 4.7 engine but its pretty simple to remove and check a number on sensor itself.
Hope this helps
21 - 37 of 37 Posts
